Lay Out Of Tiles On Shower Walls - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2013, 11:27 PM   #1
lay out of tiles on shower walls
I am tiling a shower over a kerdi waterproof system. There are 3 walls. The back wall is 96 inches tall and 49 1/2 inches wide. I am using tiles that are 12 by 12 and I was wondering what the best lay out would be.
Myside walls are 40 inches wide. Thanks.
GBH1 is offline   Reply With Quote
Old 02-06-2013, 08:21 AM   #2
Rewards Points: 492
Grout line thickness will make a difference.
I start with the finish edge pieces that go around perimeter (ceiling too), all in a straight line. Hold them up and mark with pencil. (Have many pencils ready.) Use a level to see how square whole shower box is. Vertical and horizontal lines must be level and straight.
Hold up 2 12 x 12s in a corner and mark where true edge will be on other wall, allowing for thickness of thinset. The open area on each surface needs a vertical centerline next. Mark it. Now a matter of filling in as many full or near full pieces in both directions, across (very important) and up and down (less important if your not tiling to ceiling). Allow for your groutline spacing.
Idea is to get as near as possible to full size pieces on far left and far right rows. If it turns out to be a 'sliver' (very thin piece), rework plan until something works. If you're putting in decorative contrasting tiles and/or pencil pieces, plan and draw carefully on the wall. Much easier if not going to ceiling and decorative pieces are on horizontal plane only. Then first piece at floor level can be full piece IF shower base is perfectly level. Typically not the case.
diyorpay is offline   Reply With Quote
Old 02-06-2013, 09:30 PM   #3
Thanks for the help
Cheapest shower walls possible? hoosbekah Kitchen & Bath Remodeling 2 12-09-2011 09:08 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Shower Floor 1 inch Tiles ok to Use? newmex999 Remodeling 9 12-18-2009 05:59 PM
Rotting shower walls PICTURE Sarah24 Kitchen & Bath Remodeling 6 05-10-2009 01:09 AM
