Laundry Tub In Garage - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-17-2007, 09:51 PM   #1
laundry tub in garage
Hi, want to put laundry tub in garage,not much experience, but willing to listen
have a new build with basement still unfinished so obviously I can see all the pipework,from the nearest pipework in basement to the laundry tub placement through the wall it is only about 2/4 feet away
Thanks in advance D/B
davidandbess is offline   Reply With Quote
Old 10-17-2007, 10:07 PM   #2
Hot and Cold supply are easy to route even if they are far away.
The tricky thing is your drain. How close is your proposed sink to the nearest drain vent/stack?
NateHanson is offline   Reply With Quote
Old 10-17-2007, 10:44 PM   #3
here is the view of bathroom pipework and the distance to the garage wall
Regards D/B
Old 10-17-2007, 11:16 PM   #4
Where's the vent stack for that bathroom?
Old 10-18-2007, 07:07 AM   #5
Send a message via AIM to Marlin
Remember if you have plumbing in the garage it must be heated.
Marlin is offline   Reply With Quote
Old 10-19-2007, 03:45 PM   #6
Rewards Points: 6,652
Couldn't you use a remote Shut off system, such as used for laundry rooms? Push the button, water flows for a period set by the timer. As for the drain, depending on how far from the garage, you could run a drain pipe against the wall to the door. It really depends on what you are going to use the wash sink for.
Old 10-20-2007, 05:08 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
the picture is a little vague...
as stated before, waterlines would be relatively easy to get where you want them, and depending on how things look up above, the drain might not be too difficult either.
It's really hard to tell where the sink is going to go in relation to your drainage system, but basically you're going to need a 3x2 wye cut in somewhere on that 3" line in the vicinity of your laundry sink drain, then whatever fittings you need to get the laundry sink to that location, 2" drain up to the trap arm, and 1-1/2" vent out the roof, or tied into the bathroom stack if possible, and/or depending on how many other fixtures the 2" vent is currently serving. We also always put a cleanout right under the trap arm as well.
Journeyman Plumber
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 12:09 PM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 11:38 PM
detached garage Kapt Electrical 12 01-17-2007 09:37 AM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
