Laundry Tub - Do I Need A Double? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2008, 12:43 PM   #1
Laundry tub - do I need a double?
Hi again,
I want to replace my ancient laundry tub. The one in there now is a huge double sink. The problem is that it's so big I have to have the washer and dryer split up on either side and the washer is blocking the new electrical panel. I've looked at the tubs and thought maybe a single tub would be better since it's smaller and then I could have the washer/dryer next to each other away from the electrical box. Is there any reason I should not switch to a single tub or should I just look for a smaller double tub? Thanks!
Corcoran1 is offline   Reply With Quote
Old 03-22-2008, 12:54 PM   #2
Electrician
For your information.... This one is pretty hard to enforce after the fact, but its still code... and being an electrician, nothing is more aggravating then this scenario...
chris75 is offline   Reply With Quote
Old 03-22-2008, 12:57 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Yes replace it with a single tub.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-22-2008, 01:06 PM   #4
Electrician
One other option is that newer washer/dryer units are stackable... so if you really love your double sink you can look into this...
Old 03-22-2008, 06:21 PM   #5
I don't love the double tub so that's no problem. I just didn't know if there was some practical reason to keep it a double tub. I think I will go with the single. Now the problem is how on earth I'm going to get the old one out. It's heavy!
Old 03-22-2008, 08:37 PM   #6
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
If its an old concrete laundry tub, a sledgehammer, couple of 5 gallon buckets and alot of energy is how you get it out.
JDC is offline   Reply With Quote
Remodeling laundry closet bplaird Carpentry 11 05-09-2011 05:44 PM
Upstairs Laundry Room Install Matt Burks Remodeling 3 08-21-2007 11:12 PM
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 10:35 AM
Cement Laundry Tub _ Paintable? Leenders Painting 2 02-18-2007 09:02 AM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 03:08 PM
