Laundry Sink Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2013, 12:53 PM   #1
angelatc's Avatar
Laundry Sink Pump
My basement washing machine drains into a sink, where it's then pumped up and out. The pump attaches directly to the sink.
The pump only hums. Assuming that I can't repair it, any brand name recommendations?
angelatc is offline   Reply With Quote
Old 01-16-2013, 06:46 PM   #2
Rewards Points: 3,742
Disconnect it and take it to a motor repair shop,and see if it can be repaired.
Canarywood1 is offline   Reply With Quote
Old 01-16-2013, 08:14 PM   #3
angelatc's Avatar
Meh - it's a DIY forum. If I can't fix it myself, I'll replace it.
Old 01-16-2013, 08:34 PM   #4
Your call,sounds like you have an overhead sewer system.
Old 01-16-2013, 09:17 PM   #5
Rewards Points: 14,026
Just open up where the impeller is and see if it's jamed up with lint.
Old 01-17-2013, 08:34 AM   #6
Roofmaster
Rewards Points: 2,210
In the future, put a nylon stocking on the end of your washer hose to catch the lint. Joe is right. That pump is probably chocked with lint. If its humming is might be running dry. I would put the pump in a sump (Bucket Etc.) Then put 3/4 inch crushed clean blue stone around the pump. It acts as a filter of sorts
Geothermal heat pump using pool as heat sink mnschu HVAC 9 05-17-2012 08:10 PM
Draining laundry sink into washer stack? glamgirrl Plumbing 33 12-31-2011 02:02 PM
Installing utility sink in laundry room 71Whaler Plumbing 9 11-24-2011 10:33 AM
Access behind laundry sink CharlieG Plumbing 6 11-10-2010 01:37 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
