Old 04-05-2008, 10:18 AM   #1
Question
laundry sink needs wall-mount faucet - can I cheat?
I've been wanting to replace the old plastic laundry sink in my basement with a ceramic sink, and yesterday I found a perfect one at an architectural salvage place. Perfect except that it doesn't have a deck or holes for mounting a faucet, so a wall-mount faucet would be needed.
That would be possible, but only with a lot of fussing, based on the way things are set up now. What if, instead, I built a deck just behind the sink, and mounted the faucet on that? Assuming I wanted to do that, what material would be the simplest to use? e.g could I actually just waterproof some wood? Could it be that simple?
bluebee1314 is offline   Reply With Quote
Old 04-05-2008, 12:38 PM   #2
Sure. Build a "box" behind the area you want the sink and make sure you install proper studs to mount the sink on. Run the waterlines inside the box and mount the faucet to it. A few coats of Poly should make it basically water resistant. I did this to install a pedestal sink where rerouting the plumbing would have been high dollar and loads of work. I built a box with access door for any future use. You could make the area for the waterlines (supplys) that attach to the faucet, removable (held with screws) for ease of installation.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 04-05-2008, 12:45 PM   #3
Nice - thanks!
Wall mount toilet warnerww Plumbing 3 07-04-2011 09:01 PM
vessel sink drain and faucet Katmac Plumbing 17 10-11-2010 09:12 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
