Laundry Room Tie In To 90 Year Old Soil Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2012, 06:00 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 562
You can use a 4x2 san tee instead of the wye, it will gain you an inch or two in elevation. 18" is the max. height for the trap
Stick a 2x4 under the branch for the toilet if you don't wan't to go the riser clamp route.
I like to use a small angle grinder for cutting old pipes. Blades are cheaper then sawzall blade. Less vibration, no chance of crushing the pipe (which I've done). Just be sure to use safety gear
@ Beepster, If you read my list of handy tips, you can send me a check for $99.95. I got to pay my over priced CPA
Old 01-18-2012, 08:29 PM   #17
Originally Posted by plummen View Post
If there is already a "future vent" roughed in go ahead and use that,a 2" would be ideal though.
Sounds good. There is a vent that travels up next the old soil line and it goes all the way to the roof. Its the vent for the current washer drain in the basement...so I'll just use that.
Thanks for everyone's help/input. As a DIYer, I really appreciate the advice.
uwditto is offline   Reply With Quote
Old 01-18-2012, 10:28 PM   #18
Thanks for the tips.
Old 01-19-2012, 01:18 PM   #19
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
That washing machine line should run independently back to a 3" line though
plummen is offline   Reply With Quote
Old 01-19-2012, 01:44 PM   #20
Rewards Points: 660
Touche. What comes around goes around.
B
Beepster is offline   Reply With Quote
Small Yard, Tree Roots....? JayNYOne Landscaping & Lawn Care 6 11-13-2011 06:30 PM
converting laundry room to bathroom brandisophie Plumbing 8 11-07-2010 01:10 PM
Laundry room in the basement Trish99 Remodeling 3 10-18-2009 11:26 PM
Supply and Return from Laundry Room bjstewa HVAC 7 03-02-2007 11:39 PM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 03:08 PM
