Laundry Room Remodel - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2010, 10:54 AM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
1 : Can't install trap for clotheswasher below floor
2 : Length for standpipe for clotheswasher cannot be less than 18" nor more than 30 "
3 : Standpipe needs to stay vertical (greater than 45*)
I'm sure there are more.
Journeyman Plumber
Old 06-06-2010, 11:19 AM   #17
how about this
fpeftw is offline   Reply With Quote
Old 06-06-2010, 03:18 PM   #18
Originally Posted by Alan View Post
I doubt with the vent going horizontally right off the drain.
yea it would be legal here. we can extend a small single fixture (under 2") waste 12' from a vented line. the vent can run horizontal. the only restiction is that the vent must terminate at least 6" above flood level of fixture it serves. I didn't write the code but we have been following it since 1933. it works
just a guy is offline   Reply With Quote
Old 06-06-2010, 07:55 PM   #19
Doing it myself
Alan's Avatar
So then a washing machine doesn't qualify since it's not under 2" ?
Journeyman Plumber
Old 06-07-2010, 03:21 PM   #20
I should have said 2" or under, but we are also allowed to run a washing machine with 1 1/2", not that I do it but it's allowed.
Our codes are published on line @ Phila.Gov. then go to "License and Inspections" they have a code libary there.
Old 07-10-2010, 11:33 AM   #21
Just wanted to post and show how the remodel went. Although not thru with the sheetrock or floor, the washer and dryer and Hot water heater are in and functioning for several weeks now. Drain for washer works great. Vent pipe works fine. no odor. Will install side vent kit for dryer, then complete sheetrock and install counter top.
pinkertonpv is offline   Reply With Quote
Basement laundry room secutanudu Electrical 9 04-23-2010 03:23 PM
Laundry Room Drain Set-Up - is it okay? bmb2m9 Plumbing 1 02-02-2010 10:49 PM
Laundry room plumbing mikev88 Plumbing 1 01-01-2010 03:10 PM
Options for partition in laundry room...? butterdog Building & Construction 1 12-08-2009 12:29 AM
Supply and Return from Laundry Room bjstewa HVAC 7 03-02-2007 11:39 PM
