Old 11-15-2009, 11:27 AM   #1
laundry room floor drain
Hi,
This week I am going to start converting an extra bedroom on my 2nd floor to a laundry room. I just picked up the Samsung front loaders - so we'll see how true that commercial is about noise
In any case, The room will be used as a laundry room and office and I really wanted to put prefinished hardwood floors in the room to match the rest of the house. I was originally planning on putting ceramic tile down under the machines and a curb around the machines - with a floor drain in the middle of the tile, but the stands that go under the machine won't open if there is a curb in front of the machine. I am already planning on using the SS floodsafe hoses - that automatically stut off if they burst. I'll have an auto shut off valve installed in case of a water leak as well, but I still wanted to put in a floor drain just in case. So the question is, could I put a floor drain in the hardwood floors under the machine? I know if there is a flood the hardwood would get ruined but I hate to put tile in this room. Any suggestions???
Thank you!
mazzonetv is offline   Reply With Quote
Old 11-15-2009, 09:54 PM   #2
This is another idea I saw in ASK THIS OLD HOUSE.The reason you want
to put a drain is to avoid having problems with the floor and any damage
it may cause on the room below. They (at this old house) installed
a metal pan underneath the washer with a special switch which shuts
any water once the pan is filled. You simply empty the pan after it is full
of water. This is just another idea.
gabriel246 is offline   Reply With Quote
Old 11-16-2009, 10:20 AM   #3
Nothing prevents you from installing a floor drain, but the floor might not be pitched favorably and water may still accumulate elsewhere in the room if you had a catastrophe.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
dehumidifying laundry room rocketdoctor Appliances 4 10-21-2009 02:08 PM
Laundry Room Dimension Question jonathan03 Appliances 1 01-17-2009 11:08 AM
occasional sewer gas smell in laundry room nebben Plumbing 3 03-25-2007 11:35 AM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 04:08 PM
