Laundry Machine Backup Soap Suds Into Laundry Tub. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2013, 12:42 AM   #1
laundry machine backup soap suds into laundry tub.
I have the drain and trap in for my basement bathtub and have poured cement over most of my plumbing with the exception of a small boxout arround the Tubs U-Bend.
Today, I was doing laundry and I got a small amount of soap suds coming up the pipe for where the tub is supposed to go in.
I was thinking if of attaching 1+1/2 in backwater valve vertically between the trap and the tubs drain T.
But I'm worried about:
A) I won't have enough room (without raising the tub an inch or so).
B) the valve won't work with suds.
C) it will slow the tub draining time.
So I'm looking for advice and suggestions.
Thanks.
hswerdfe is offline   Reply With Quote
Problem with Candy Smart CTDF 1007 Washing Machine (European washing machine) PBEnglish Appliances 4 09-11-2012 01:07 PM
Adding laundry washing machine hose through concrete wall, equipment rental nynhpdiy Plumbing 4 05-30-2012 08:11 PM
Do you have to close the faucet when the laundry machine is not in use jilou Plumbing 7 05-12-2010 01:24 PM
white stains improvements Appliances 1 02-20-2009 05:26 PM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 07:41 AM
