Laundry Faucet & Trap Seal Tube Connections - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2010, 03:35 PM   #1
Bri
Post
Laundry faucet & trap seal tube connections
hi there....looking for advise on how to fix a leak between my laundry faucet and the trap seal tube. The tube recently split so I replaced it and attached a compression nut on the end. I also inserted a male to male union connector to the faucet so I can attach the tube to the faucet. The tube is no longer leaking but now the joint between union connector and faucet is leaking. Am I missing something that could prevent the leaking?
Bri is offline   Reply With Quote
Old 07-01-2010, 10:51 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Can you attach an image please, your terminoligy is a little confusing. Thanks in advance.
Journeyman Plumber
Do you have to close the faucet when the laundry machine is not in use jilou Plumbing 7 05-12-2010 01:24 PM
replace faucet in laundry room nextbond Plumbing 3 09-15-2009 11:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 11:10 AM
Faucet Repair Questions? mfleming Plumbing 3 05-07-2008 10:44 AM
laundry sink needs wall-mount faucet - can I cheat? bluebee1314 Plumbing 2 04-05-2008 12:45 PM
