Laundry Drain... Long Sweep Required? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2012, 07:57 PM   #1
firstimereno's Avatar
laundry drain... long sweep required?
crawlspace house... washing machine drain, an up-running 45 branches off to a AAV in wall cavity, then thru floor, it 90s and then runs between floor joists... trap is about 6" after the 90. does that 90 have to be a long sweep?
firstimereno is offline   Reply With Quote
Old 05-23-2012, 07:53 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Need a picture
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 05-23-2012, 11:11 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 984
Originally Posted by plummen View Post
Need a picture
If aim not mistaken from your description the trap is offset and is now a running trap which is illegal under some codes. Pictures will help.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-23-2012, 11:57 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It kinda sounded like that to me too, but that description is pretty crazy.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (05-24-2012)
Old 05-24-2012, 07:17 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 776
Sounds like his p-trap is down under the floor.....mine is in the wall just below the washer box....
I think that p-trap needs to be higher.....
ddawg16 is online now   Reply With Quote
What is this thing?? Todd54 Plumbing 10 05-09-2012 05:18 AM
New Drain and Overflow assembly not fitting properly to new tub - Help plz amodoko Plumbing 19 12-21-2011 03:28 AM
Laundry Room Floor Drain 06Honda Plumbing 2 11-23-2011 08:53 PM
Why won't my laundry tub drain? tigereye Plumbing 11 03-29-2010 11:08 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
