Laundr Y Drain Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2008, 09:15 PM   #1
Question
laundr y drain issue
I decided to add a laundry tub to my laundry room. There was one in the past but I replaced it will just a drain pipe for the laundry the past few years. Well I decided to add one back. I hooked it up with a 1.5" pipe running to a P Trap and then running up to the laundry tub. So I set the Washer to drain in to it. Well I ran the washer and now the tub is not draining out. no other fixtures in my house are having issues. Do I need to add venting or something? Why will it not drain? PLEASE HELP . Note I did auger out the pipe prior to hooking up the sink and it seemed OK.
THanks in advance for helping the newbie. GReat site by the way.
toddtrain is offline   Reply With Quote
Old 02-23-2008, 12:05 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
ALL fixture drain systems have to be vented after the trap, or they won't drain properly.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 03:15 AM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
