Old 02-08-2009, 06:37 PM   #1
Exclamation
large hole in main sewer
We have a cast iron sewer line that is buried in our basement floor, that has a large hole in it. In the top, about 3 inches long and an inch wide. The pipe is half buried in the floor. How do we go about fixing it? Sorry if this does not make sense... any help would be appreciated
K&D3 is offline   Reply With Quote
Old 02-08-2009, 07:14 PM   #2
the Musigician
DangerMouse's Avatar
cut a 4"x2" rectangle from a plastic milk carton, put a small hole in the center and put string through it. shove it in the hole, then use a popsicle stick to 'tourniquet' it snug to the inside. then mix up some waterproof epoxy repair (marine epoxy/gas tank repair) and fill it in. when hardened, cut off the string and add a small bit to cover it too.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 02-08-2009, 09:36 PM   #3
Rock on, good idea
Sewer main NEW LINING? DragonLady Building & Construction 2 11-02-2007 06:46 PM
DIY replacement of a section of sewer main jcarlsonNSP Plumbing 3 10-03-2007 01:00 AM
Sewer gas smell in basement when doing laundry on main floor Bornintc Plumbing 1 01-17-2007 12:04 PM
toilet hole Q - not to the sewer Jumper55 Plumbing 1 10-21-2006 11:07 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
