Large Drain Cover For Tub? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-14-2008, 10:54 PM   #1
large drain cover for tub?
i just had a tub liner installed in my old tub. i have had many workers in and out of the house. somehow the liner got damaged next to the drain.
is there a larger metal drain that i could buy which would cover this damage?
there is a small dent right next to the drain. i think my drain is 1 1/2 "
if i could find a drain which covered 2 1/2" it would cover over the dent
i could remove the 1 1/2 drain and replace it. does anyone have any suggestions?
renee18103 is offline   Reply With Quote
Old 03-15-2008, 08:06 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Probably not going to find one that size, there pretty much the same size.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
