Laminate Flooring - Is It Installed Under Bathroom Cabinets? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2007, 05:33 PM   #91
Well guys thanks so much -- I am leak free and it's working well. I still may rebuild the upper works to get that tee facing the right way, but now the nice part is with the rubber base, I can remove the PVC without having to cut and dig out the whole vanity.
I realize it's not a perfect job, but it's working, and I learned a lot. Thank you all so much for your help and your patience.
BDPNA is offline   Reply With Quote
Old 02-06-2007, 05:40 PM   #92
Journeyman Plumber
Ron The Plumber's Avatar
Your welcome, glad we could help you out.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-07-2007, 12:02 PM   #93
Try not to use a hammer to "cut" the pipe next time.
Hope that there is not any damage further down from hitting the pipe with the hammer.
Looks good.
redline is offline   Reply With Quote
Laminate Flooring Question cacell Flooring 7 03-30-2017 08:01 PM
Laminate Flooring Outdoors fogel1497 Flooring 1 05-28-2007 03:39 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
Laminate Flooring Install Renovator Flooring 6 04-24-2006 10:42 PM
