Lack Of Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-17-2010, 06:08 PM   #1
Lack of Hot Water Pressure
My hot water pressure drastically reduced last week. A few local plumbers in the area say it's calcium. per their direction i removed the hot water handle in the shower and all the parts until i got to the valve it's self. it's a plastic piece that seems to be glued in there. is there a way to get it out, or do i have to break it out and put in a new one. they say if i can get it out i can clean it off.
wolfe1lt is offline   Reply With Quote
Old 09-17-2010, 06:49 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
wolfe, Welcome to the Forum
Have you completely removed the Shower Head?
Don't mess with the shower handle for now. You may have misunderstood their directions. Put the handle back and remove the Shower Head. Then turn the the water full on to test for the water flow. There may be a clogged water restrictor in the shower head.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-18-2010, 12:35 PM   #3
Was the drop in pressure just in the shower, or all fixtures? The water pressure going into the water heater determines what the outlet pressure will be.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-18-2010, 02:05 PM   #4
Rewards Points: 1,088
You'd be amazed at how your water pressure increases when you remove the aerator.
handy man88 is offline   Reply With Quote
Old 09-18-2010, 02:17 PM   #5
Seasoned DIYer
Rewards Points: 150
Soak the entire head in vinegar.
HVAC_NW is offline   Reply With Quote
Old 09-18-2010, 03:27 PM   #6
HVAC / Plumbing
Save yourself a some headakes... Throw that sucker away
kenmac is offline   Reply With Quote
Old 09-19-2010, 02:29 PM   #7
thanks, for all the replies. to update the situation. the lack of pressure is primarily in the hot water in the shower. the lack of pressure is apparent in the bath tub spigot. it is also in the hot water for the washer. not much pressure there anymore. i would think this puts the problem before the shower head.
i was able to remove the valve from the pipe on the hot water for the tub. i let the water run for a long time and found little to no calcium. i also turned off the power to the water heater, hooked up a hose to the bottom and completly drained if for over an hour until it stopped. then i hooked up my vacume cleaner to the bottom of the heater and sucked out the remaining water. very little if any calcium was discovered. it kind of looked like white paint chips.
would appreciate any additional insight this leg work provides.
the other fixtures don't show much drop in pressure, but there is a little.
Old 09-19-2010, 05:40 PM   #8
Low hot water pressure
Help! This just happened to me. All of the sudden there is low hot water pressure in all my faucets. Must be a problem at the in or out of the water heater. Any suggestions on how to really diagnose this?
rancherjerry is offline   Reply With Quote
Tags
hot water , pressure
Replaced water heater, still smelling sulfur in hot water & Low water pressure aminus21 Plumbing 2 07-21-2010 05:40 PM
Water pressure dropping tucsoncop Plumbing 2 04-25-2009 01:19 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
Water pressure and temperature billvasko Plumbing 9 06-02-2008 10:23 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
