Lack Of Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2012, 08:35 PM   #1
Lack of hot water
I'm having a problem with our hot water in our upstairs shower. The water never seems to get hot enough. The rest of the faucets in the house don't have a problem getting hot enough. The house is older with a Kohler faucet. I tried taking the mixer apart and adjusting the adjustment screw, but it is completly stripped out and won't move. I pretty sure it's the mixing valve, but I was wondering if they sell some kind of rebuild kit so I don't have to tear into the wall. Any help would be appreciated...
joster1 is offline   Reply With Quote
Old 02-07-2012, 08:52 PM   #2
Rewards Points: 582
really need a picture to say for sure..but should be able to get new cartridge for unit???
Old 02-08-2012, 05:02 PM   #3
i don't think that there is a cartridge. It's an old Kohler all brass mixer. If that makes helps.
Old 02-08-2012, 05:47 PM   #4
Rewards Points: 582
there should be some kind of mixer inside that unit to control hot-cold mix????
Old 02-08-2012, 05:53 PM   #5
Rewards Points: 14,010
No picture, no mention if it's a single handle or two handles hard to say.
To change the whole unit out its done behind the wall the shower is. Right where there should have been an access panel in the first place.
ben's plumbing (02-08-2012)
Old 02-09-2012, 06:27 PM   #6
It's a single handle. I'm going to pull it out this weekend and take a picture and post it. Thanks for the help
Old 02-09-2012, 07:07 PM   #7
DIY staff
Rewards Points: 7,174
There is a cartridge---find a real plumbing supply house that will be open---call and make sure they have the full rebuild kit---on some models the front piece of the unit falls apart and needs replacing along with the cartridge---big box store might not have that on hand.
Old 02-09-2012, 07:17 PM   #8
Rewards Points: 120
A different spin, but galvanized plumbing by chance?
Old 02-09-2012, 07:27 PM   #9
I'm pretty sure it's galvanized. Another symptom that is strange is that if I have the shower on full blast hot, there is almost no hot water if I turn the hot water in the sink in the same bathroom. That sink has two handles.
Old 02-10-2012, 06:53 AM   #10
Rewards Points: 120
If so, it could be that the supply line is crudded up, restricting flow.
Old 02-13-2012, 07:44 AM   #11
I think this is what the problem is... I took off the mixer and turned back on the water. Nice stream out of the cold water. almost nothing out of the hot water side... Not good.. Is there anything I can do? Thanks for the help....
Old 02-13-2012, 04:10 PM   #12
Rewards Points: 120
The only soultion that I know of is to replace the line, with copper or pex, not galvanized, and take it all the way back to the souce, as it's one of those do it now or do it later type things. First though, just to be certain, I would chase the line all the way back, just to make sure that a valve hasn't been accidently bumped; unlikely, as it probably has old gate valves, if anything, and not very likely easily bumped, but worth a shot. And, since you will probably have to open wall cavities, I would plan on replacing hot and cold lines.
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Lack of hot water Tony Paull Plumbing 4 12-23-2010 02:30 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
