L-sweep Elbows - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2013, 04:50 PM   #1
L-sweep elbows
Where may I purchase a Charlotte Part No. 305 (3X3X2, long-sweep, 1/4 bend elbow with High Heel inlet?
Lsweep is offline   Reply With Quote
Old 05-03-2013, 05:00 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
never seen it in long sweep- only medium.
Try special order at a big box store
Old 05-03-2013, 06:30 PM   #3
all the states i have worked in did not allow heel outlet ells to be used for anything but vents.
Old 05-03-2013, 07:25 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
IPC This fitting is a no go..
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-03-2013, 07:57 PM   #5
Plumber
Rewards Points: 904
Been awhile since I've used one- not sure if they're legal anymore by UPC.
When I did use them, it was inplace of a 3" tee with the top bushed down
Old 05-03-2013, 10:33 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'm not sure why you would need one in LS either....
If it's for anything other than (wet)venting, it would be illegal in UPC as well.
Can you give us a diagram of what exactly you're trying to do?
Journeyman Plumber
What is the difference between a quarter bend and short sweep 90? troyce1 Plumbing 3 12-17-2012 09:10 AM
Shower Spider Valve Outlet: Elbows, Braided, ?? yogi_bear_79 Plumbing 6 11-03-2011 10:44 AM
Threaded Elbows mtk369 Plumbing 6 02-17-2011 08:26 AM
Flex for elbows? kindejj HVAC 9 06-25-2010 09:40 PM
Long sweep 45 degree elbows wtroger HVAC 5 09-22-2009 12:46 PM
