L/R Drain Bath/shower Over Center Drain Location In Floor? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2007, 12:09 PM   #1
Rewards Points: 324
L/R Drain bath/shower over center drain location in floor?
I am finishing my basement. Currently the bathroom is spec'd out to be 60" wide. The current drain is located in the center between the two side walls or a center drain location. I want to install a left drain location bath/shower one piece module. It sounds like a need to build a base and lift the entire assembly up high enough to get the 1/4" slope of pipe from the drain on the tub to the drain in the floor, but do I need to put in a P Trap under the tub or is there already one under the concrete?
tigerbalm2424 is offline   Reply With Quote
Old 12-04-2007, 01:16 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
If the basement plumbing was properly roughed in, it should have a trap built-in for a tub/shower and all drains should already be properly vented. A trap is installed under the sink as it is installed, and toilets have built-in traps.
The easiest way to check for a trap is to pour water in the drain and shine a flashlight down it. If you can see standing water, there is a trap. If not, you need to install one.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-04-2007, 01:26 PM   #3
Rewards Points: 324
Good Luck!
Mike
Thanks! So, if there is a trap already underneath in the concrete then I could just run straight PVC from the tub drain to the floor drain right?
Thanks again-
Water and Drain Line Location Material Tester Plumbing 1 11-27-2007 07:40 PM
Bathtub drain location kendallk Plumbing 3 11-11-2007 11:02 AM
Anyone know if it is code for a utility room floor drain? tigerbalm2424 General DIY Discussions 3 10-17-2007 10:48 AM
floor drain with a stopper amakarevic Plumbing 3 08-13-2007 12:12 PM
Basement Floor Drain amazinlittledevil Plumbing 8 01-04-2007 01:17 PM
