Kraus Faucet Shank Too Short For Granite Countertop - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2011, 06:16 PM   #1
Kraus Faucet shank too short for granite countertop
Need to install a Kraus Faucet in granite countertop, but faucet max
dimension is 1 1/2 in. and granite installation needs 2 3/8 inches. What
kind of extender can I use?
eyeglass is offline   Reply With Quote
Old 09-21-2011, 06:29 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why?
The Following User Says Thank You to Bud Cline For This Useful Post:
eyeglass (09-21-2011)
Old 09-21-2011, 07:10 PM   #3
DIY staff
Rewards Points: 7,174
You will need to return the faucet and get one designed for a thick installation--sorry--
Old 09-22-2011, 08:40 AM   #4
Rewards Points: 1,668
Why is the countertop 2 3/8" thick?
bob22 is offline   Reply With Quote
Old 09-22-2011, 09:33 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Probably including thickness of plywood below. If you cut out the plywood where the hole for the faucet needs to be will it fit?
If not you'll have to contact the manufacturer with your specific make and model to see if they even offer an extension.
Journeyman Plumber
Old 09-22-2011, 10:53 AM   #6
Must be pretty thick granite/plywood. At most granite would be an inch and ply 3/4" I'd think.
Old 09-22-2011, 05:19 PM   #7
Smile
Thank you all for your response. I really appreciate.
As I understand from my granite fabricator, a total of 2 3/8" faucet
shank would allow a proper installation; he says he is using 1/4" plywood.
I also learned from various plumbing supply stores in my area that an
extender made for the Kraus faucet (the Kraus faucet has only 1 1/2" shank) would support the proper installation but Kraus does not have one. Also, there are no generic extenders. Other mfgs such as Delta, Moen, and Am Standard have their own.
My question is: are their comparable extenders or generic ones that would work.
With only 1/4" plywood, cutting out the plywood would not satisfy the
needed length, would it?
Thank you for your help.
Old 09-22-2011, 06:22 PM   #8
You and he are on-site. I just don't see why you ned 2 3/8" when you might have 11/2" of countertop and plywood to go through.
Old 09-22-2011, 08:10 PM   #9
Doing it myself
Alan's Avatar
I agree ^^^^^
It sounds like you might need to double check with your granite guy. Don't think i've ever seen granite that thick, and why set it on 1/4" plywood? What exactly is that going to do besides run the bill up?
Journeyman Plumber
Old 09-22-2011, 08:24 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Same here. Never any plywood, no reason to use it. Granite here would be 1-1/8" thick max in all the cases I know of.
Vellel faucet too short sanjulee Plumbing 4 08-30-2012 08:22 PM
Warped Countertop at Kitchen Faucet Avanzi Kitchen & Bath Remodeling 6 03-09-2012 12:04 AM
Problem: bar faucet shank is too short vluzhko Plumbing 7 06-04-2010 09:06 AM
Putting on new countertop how do I remove this faucet? doogie88 Plumbing 12 10-07-2008 03:51 PM
New countertop, sink and faucet darlenep Project Showcase 4 08-17-2008 09:33 PM
