Old 08-10-2008, 08:54 AM   #1
Kohler toilet running constant
Hello:
My toilet keeps running water in the fill tube I cant get it to stop. I am on a well. Thanks.
econdave is offline   Reply With Quote
Old 08-10-2008, 09:02 AM   #2
ccarlisle's Avatar
Lower the ball float...?
ccarlisle is offline   Reply With Quote
Old 08-10-2008, 09:26 AM   #3
yeah, did that. still running out the fill tube not full blast, just a constant flow.
Old 08-10-2008, 10:41 AM   #4
Mine did that, I had to replace the fill valve and flapper.
darlenep is offline   Reply With Quote
Old 08-10-2008, 10:54 AM   #5
Send a message via AIM to Marlin
Is the water level over the overflow tube?
Try gently lifting the flat all the way up. Does the water stop? If it does you need to adjust the float level. If that doesn't stop it you need to replace the fill valve.
Marlin is offline   Reply With Quote
Old 08-10-2008, 01:06 PM   #6
ccarlisle's Avatar
Sometimes a piece of dirt gets trapped in the valve that controls the water inlet at the end of the ball float. I've oftern taken the little 1/4" tube that squirts water to the bowl, disconnected that from its clip and used the water jet to clean that valve. At the same time I lift the ball float up high so it forces the valve to close. If it closes, then your problem might be on the way to being fixed - without you rushing out for parts and peeing in the woods.
Old 08-10-2008, 02:48 PM   #7
replaced the flush valve, everything is o.k. thanks for the advice.
More On This Topic
Hi! This is John on behalf of Expert Village. In this video clip, I will show you part 5 for installing a ball valve. The next thing that you need to do is take a piece of sandpaper or emery cloth, and we are going to clean the ends that are going to go... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will show you step 9 of our process for installing a ball valve. The next thing that we want to do is go ahead and open up our ball valve so that water will flow through our pipes. Again... Read More »
Once you get all of your plumbing in. Now on this sink, the drain is set forward from the drains coming out of the sink because of the remodel. This inlet right here is going to go to the dishwasher on this side of the sink. We had to use a flexible hose... Read More »
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
How Do Ball Valves Work
How Do Ball Valves Work by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be answering the question what is a ball valve. A ball valve that has been already installed looks like this. It will go between two pieces of pipe, and it will either allow or... Read More »
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet running inside bowl leroyme Plumbing 4 08-21-2007 08:50 PM
Toilet Keeps Running Rod Plumbing 5 01-28-2007 08:39 PM
30 year old kohler toilet part chubdo Plumbing 2 06-05-2005 04:41 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
