Old 01-04-2012, 04:00 PM   #1
Kohler single handle shower - no cold water
I'm happy to provide more info if it helps... I'm having a heck of a time getting answers anywhere (Kohler included) so i appreciate any help anyone can give.
I'm not getting any cold water from my Kohler single handle shower. Even when turned just barely on, it's piping hot. I have the k-2971 valve. Help?
molomoore is offline   Reply With Quote
Moen Single Valve Shower Handle problem! F8James Plumbing 3 04-16-2011 05:32 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
No hot water pressure in up stairs shower. Cold is fine. my4boyz27 Plumbing 1 09-09-2010 04:31 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 09:19 AM
