Kohler Single Handle Shower Faucet Loose - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-30-2012, 12:19 PM   #1
Liv
Kohler single handle shower faucet loose
Hi there-
Hopefully one of you guys can help me out. We had our bathroom remodeled recently and installed the Kohler R1920-4-BN shower/tub faucet (photo attached). The contractors came back to fix a leak before we ever used the shower, and today we noticed that the handle is now loose. I assume this may have happened while they were fixing the other issue.
Just the handle portion is a little wobbly, and we can't figure out how to remove the handle to tighten it. We can't locate a set screw anywhere. The back plate behind the handle is grouted to the shower wall. Looked everywhere online with no answers! Help!
Thanks a ton.Name:  kohlerfaucet.jpg
Liv is offline   Reply With Quote
Old 01-30-2012, 12:40 PM   #2
DIY staff
Rewards Points: 7,174
I didn't look this up--But typically there is a hole on the bell shaped escutcheon --there should be a set screw (allen wrench) inside that hole---
Old 01-30-2012, 10:36 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
NOPE!
New kohler stuff (at least the shower trims that i've put on recently) are screwless.
(sort of)
You take your rough in valve in the wall, after finish, you screw a plastic plate to it that has a female thread in the center, push the handle onto the splines while you've got the handle aligned where ya want it, and thread the escutcheon into the plastic plate all while holding the cover plate where it needs to be so it doesn't get scratched.
It's actually pretty easy, and it looks slick, but i don't really care for the plastic threads much. I'm not sure that there's much to be done to just tighten the handle, unless the whole valve is loose inside the wall.
Journeyman Plumber
Old 01-30-2012, 10:47 PM   #4
Doing it myself
Alan's Avatar
Perhaps there's a stem extension on it for that particular style that is loose.
Journeyman Plumber
Old 01-30-2012, 10:51 PM   #5
Liv
Thanks for your help. This is what it looks like- the handle is wobbly and loose where the small gap is. It can move around quite a bit in every direction. Do you think they may have broken it? I'd hate to call the guys out who installed it again- but that looks like what we might have to do...
Old 01-30-2012, 10:52 PM   #6
Doing it myself
Alan's Avatar
Tried to find the installation guide for the trim for that darn thing, but I noticed at the bottom of the page :
"RETAIL AVAILABILITY ONLY
Journeyman Plumber
Old 01-30-2012, 10:58 PM   #7
Liv
Yeah- I looked everywhere online and found nothing. Pretty sure the guys that did the work in our bathroom threw it away...thanks a lot for the help, though
Old 01-30-2012, 11:17 PM   #8
Doing it myself
Alan's Avatar
Anyway, the ones that I've put on recently, you just hold onto the lever part of the handle and rotate the bell part of the handle counterclockwise. It should thread right off. Careful of the cover plate when you do, it will fall to the floor if you don't hold it as well.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
KidsNurseMJ (11-13-2015)
Old 11-13-2015, 05:22 PM   #9
Rewards Points: 2
This worked for me, Alan. Thanks SO much!!
KidsNurseMJ is offline   Reply With Quote
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 25 01-26-2014 06:31 PM
Removing shower faucet handle johnnyjc33 Plumbing 0 11-01-2011 12:29 PM
Kohler Trend Shower Faucet drips rondom Plumbing 0 02-25-2011 10:23 AM
Broken Shower Faucet Handle DFT Plumbing 1 02-23-2011 09:55 AM
Double Handle versus Single Handle kitchen faucet Lindahoney Plumbing 7 11-20-2007 10:36 AM
