Old 02-08-2012, 04:43 AM   #1
kohler shower mixing valve adjustment
i have a kohler revival # T16116-4A or T16114-4A shower mixing valve problem. I am getting very litlle cold water and can not even take a shower because it is so hot. How do I adjust it?????
mattmcwill56 is offline   Reply With Quote
Old 02-08-2012, 07:32 AM   #2
Most valves have a max hot setting, which is set by a toothed gear or similar under the handle. But you should be able to adjust the temp up to the hottest setting by simply turning the handle. You might also consider reducing the temp of the water heater. That should be set at 120deg or lower.
It is also possible that you have a bad cartridge.
The Following User Says Thank You to Just Bill For This Useful Post:
mattmcwill56 (02-08-2012)
Old 02-08-2012, 08:23 AM   #3
i just installed one in my house to pass an inspection for code, it's a honeywell and it has a knob that when you loosen the screw that holds it , it will move and allow you to turn the temp adjustment then retighten the knob to relock.
christoff is offline   Reply With Quote
The Following User Says Thank You to christoff For This Useful Post:
Old 02-08-2012, 05:14 PM   #4
if the faucet was working good for awhile then stoped without any thing being done ....replace cartridge...
Old 09-15-2012, 01:44 PM   #5
My issue is that you turn it on and it gets hot but as you turn it back towards "cold/off" it stays hot then suddenly gets very cold near the end like hot/cold not mixing well. Can this be adjusted, repaired or needs replacement?
FJS961 is offline   Reply With Quote
Old 09-15-2012, 03:41 PM   #6
Follow steps 21 through 25 from here (http://www.us.kohler.com/webassets/k.../1104832_2.pdf).
If that does not solve your problem, call Kohler. Your cartridge may be covered under their lifetime warranty.
allthumbsdiy is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Drywall Around Mixing Valve in Shower DaveTile Drywall & Plaster 4 04-18-2011 10:11 PM
New shower valve, no hot water? Chris112 Plumbing 0 03-19-2011 07:21 PM
No cold water out of mixing valve? apex_predetor Plumbing 10 03-17-2010 05:25 PM
Shower valve problem stephanieb_1001 Plumbing 1 06-24-2009 05:37 PM
