Kohler Persuade Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-02-2010, 07:35 PM   #1
Has anyone installed a kohler persuade toilet? The install went well till I got to the rods of the dual flush push buttons.. The directions state to insert the rods into the holes in the push button housing, then press down on the push buttons until they click into place. The problem is that the rods are about 6-7" long and they seem to be too long. They stick out of the push button housing about 3-4". Do they need to be cut?
handyman 2 is offline   Reply With Quote
Old 10-02-2010, 07:46 PM   #2
the Musigician
DangerMouse's Avatar
Not sure myself, but I would not cut the rods. Re-read the directions. You're likely missing an important move.
DM
Old 10-02-2010, 08:52 PM   #3
Just cut the rods to the correct legnth and fluuuuuuussssshhhhh!!! It works perfectly. This toilet has some flush on the #2. Now we will see ow much water we will save with the dual flush. Sometimes you have to use common sense because the manufacturer has poor directions. You have to allow yourself over an hour to install this toilet it looks great, very streamline rock solid, and seems to work well. Thank you.
Old 10-03-2010, 11:25 AM   #4
I've never had to modify a brand new kohler part, I just hope you didn't set yourself up to get screwed later
the_man is offline   Reply With Quote
Old 06-19-2011, 07:33 PM   #5
I'm going through the same exact thing right now. My K-3723 Kohler toilet has the rods and they are TOO LONG.
I'll probably cut them also, unless I can't find better instructions in the next few minutes of my Internet research.
CZ DIY is offline   Reply With Quote
Old 06-19-2011, 09:41 PM   #6
I said screwit and cut the rods to 3" exactly. An addition 1/16" might have worked also.
Install of the Persuade toilet was difficult'ish. The directions were an absolute joke. The brackets to hold the toilet in place are also a complete and sad JOKE.
When installing the cover, one of the retaining nuts worked loose so I have to figure out how to get my hand up under the toilet to hold it in place.
But, it flushed properly the first try. And I like the looks.
Not too happy about the rear of the toilet being open though. I hear "noises" more easily.
As you can see in the pic below, the directions suggest putting the rod into the holes on the tabs you see. But those holes are too small!
Kohler Persuade Toilet-img_3507.jpg   Kohler Persuade Toilet-img_3503.jpg   Kohler Persuade Toilet-img_3506.jpg   Kohler Persuade Toilet-img_3508.jpg   Kohler Persuade Toilet-img_3509.jpg
Old 06-20-2011, 09:55 PM   #7
Still going...
ChrisDIY's Avatar
Rewards Points: 508
That was our original choice for master bath, however have read multiple complaints about the dual flush or lack of it. Going with Toto Aquia which still sort of looks well with Kohler Escale.
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 06-20-2011, 10:32 PM   #8
There are different revisions of this Persuade toilet. I went with the newer, higher GPF rated Persuade.
I fixed the loose nut issue tonight. Was able to barely reach a screwdriver up under there to hold it in place as I tightened the lid screw.
One thing I don't like that I forgot to mention, is the water hose exits only on one side, the left side. Wish I'd known that before installing my water line on the right side. sheesh.
Worked out well though. I just got a 12" extension and ran it behind the toilet.
Old 06-21-2011, 10:31 AM   #9
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Unless they changed it you also had to lean toilet to the right (from standing in front) so you had to have room for this. I probably won't do the water line for toilet in master until I have it in the room in the box. Get a load of the Kohler Hatbox toilet install and rough-in.
--Chris the DIY Guy
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 6 01-14-2016 10:43 PM
Kohler toilet flush valve yarp1 Plumbing 2 04-01-2010 08:59 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Kohler toilet running constant econdave Plumbing 6 08-10-2008 01:48 PM
30 year old kohler toilet part chubdo Plumbing 2 06-05-2005 03:41 PM
