Kohler Forte Issues - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-19-2013, 07:39 PM   #1
Kohler Forte issues
The base seems to be rubbing against something and makes a squeak when you move the faucet left to right. Any ideas?
valpd is offline   Reply With Quote
Old 06-19-2013, 07:53 PM   #2
DIY staff
Rewards Points: 7,174
Call Kohler---there is an O-ring between the bottom and the moving faucet--it may be binding up---is the ring with the two screws under the counter tightened properly? If that is not tight---you will also get the sound you are describing.
Have someone move the faucet while you watch the retaining ring under the sink.
Old 06-19-2013, 09:18 PM   #3
Yes the ring is tightened. The screws are also right. I just don't know why all of a sudden when you move the faucet the top lever is not supposed to shift. It shifts slightly about an inch for some reason that I can't figure out.
Old 06-19-2013, 09:22 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 348
sounds like a loose screw under the handle.
Old 06-19-2013, 09:28 PM   #5
I have no clue how to get under the handle. There are some links on their website, but I can't seem to find out how to do it.
http://m.us.kohler.com/mt/www.us.koh...egoryId=432333
Old 06-19-2013, 09:31 PM   #6
Diagrams don't show any screw under the handle.
Old 06-19-2013, 09:35 PM   #7
Plumber
Rewards Points: 348
I'm confused- does the faucet body squeak when turned or is the handle loose?
Old 06-19-2013, 09:58 PM   #8
When I move the faucet left or right the handle should not budge. It moves about an inch with a slight squeak that I heard from the base. Something somehow loosened up.
temperature and pressure issues jpa137 Plumbing 7 04-04-2012 10:48 PM
Replacing shower head and faucet puzzle, moen to kohler rjwrightohio Plumbing 3 11-07-2011 08:02 AM
House settling issues gmvshort Building & Construction 3 02-22-2011 07:26 AM
Spray foam - code issues? upinsmoke Building & Construction 1 05-10-2010 08:47 PM
