Kohler Bathroom Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-07-2010, 09:35 AM   #1
Rewards Points: 320
Kohler bathroom faucet
I have a Kohler Forte two handle bathroom faucet. I installed this faucet about 5 years ago. One of the handle shutoffs is starting to leak where the handle meets the bonnet. I cannot remember how I installed this and I cannot find the installation instructions. This is installed on a granite counter top. If I remember correctly I had to silicone the base of the handles to the granite. How do I get the handles off? I assume that there is probably a stem cartridge of some kind that I will need to replace. Do I need to go underneath the sink and loosen the bolts holding the entire assembly to the counter top or can I remove the handles without removing the whole assembly? Thanks.
teamo is offline   Reply With Quote
Old 12-07-2010, 09:54 AM   #2
the Musigician
DangerMouse's Avatar
Any pics? That'd help.
DM
Old 12-07-2010, 12:12 PM   #3
Is this a three piece faucet? Typically you won't need to remove the whole thing from the granite. Is there a little allen head screw/bolt holding the handle on? Or is there a sleeve under the handle which screws on the stem? sometimes you unscrew that sleeve and the handle comes off. Good Luck!
broox is offline   Reply With Quote
Old 12-07-2010, 03:00 PM   #4
Tizzer's Avatar
Rewards Points: 460
Maybe this might help.
http://wetheadmedia.com/kohler-forte...-repair-guide/
Tizzer is offline   Reply With Quote
New bathroom faucet - drips... strange situation J187 Plumbing 7 11-30-2010 04:43 PM
Need help removing Delta bathroom faucet Mr_allthumbs Plumbing 6 06-01-2010 04:50 PM
Kohler Karbon kitchen water faucet: Does anyone have one? lucylu092910 Plumbing 0 04-22-2010 02:17 PM
Bathroom Faucet rrizz Plumbing 8 04-12-2010 07:32 PM
Leaky Bathroom Faucet w No Markings cmcwittig Plumbing 6 12-23-2008 09:55 PM
