Kohler Aqua Piston Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-18-2013, 07:59 AM   #1
Rewards Points: 79
Two weeks ago installed a new Kohler comfort height(my words) commode with a Aqua Piston flush valve, all is well except the commode tends to refill every so often (i assume a leak past a seal on the flush valve), I took her apart and the seal on the center rod looks good, is there also a seal further down on the base where it contacts the tank. Any suggestions greatly appreciated.
Richard LaBarre
vabear is offline   Reply With Quote
Old 07-18-2013, 05:02 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
if you bought the toilet at home depot you might have ended up with a b grade, maybe a defective valve. take it back.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
jmon (07-18-2013)
Replacing shower head and faucet puzzle, moen to kohler rjwrightohio Plumbing 3 11-07-2011 07:02 AM
how to reduce mositure issue on basement? diy001 Building & Construction 0 10-28-2011 12:44 PM
Perplexing AC issue AvalonGirl HVAC 22 08-17-2011 06:49 PM
Ceiling issue wooten General DIY Discussions 5 06-06-2011 07:20 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
