Old 11-08-2012, 12:53 PM   #1
Knowledge check about installing toilet in basement remodel project
Hi all,
Just to check knowledge on the steps to install a toilet, tub, and sink to stub-outs in a basement project my buddy and I will be working on...
Toilet...
1) Tile around and up to the 4" stub out of the slab
2) Cut the stub flush to the finished tile floor height
3) Install the closet flange into the 4" waste line
4) Install the toilet and supply line
Sink...
1) Add a P-Trap to sink drain
2) Connect the P-Trap to 2" drain pipe
3) Connect the supply lines
Tub...
1) Line up the tub to the drain
2) Connect the drain to the tub
3) Add cement leveler under the tub to stablize
4) Install all supply lines and trim
I realize I've just listed generally. So, please add in to this list as needed...
Thank you.
oodssoo is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Installing radiant heating in a basement and general basement questions... CarlsonRower General Discussion 6 12-09-2011 01:32 AM
Moving my Toilet Drain and Installing a Shower Drain Hahny Plumbing 3 04-13-2011 12:22 PM
Adding Basement Bathroom. Rear discharge toilet install question paulyjsob Plumbing 6 03-29-2011 03:55 PM
basement bathroom remodel janev Plumbing 3 03-12-2011 11:11 PM
