Knocked A Hole In The PVC Going To Septic Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2011, 03:41 PM   #1
Rewards Points: 121
Knocked a hole in the PVC going to septic tank
So I was digging and while I thought I was not too close to the main run outside to the septic tank, I was. Knocked a hole in the sch 40 pipe. I guess I need to cut a section out and replace? It's right near some major roots and won't be easy.
Any tips to make it easier? I know there will be a bunch of digging in the hard clay to have enough room to work with. Oh well...
Thanks in advance for any help from you guys who have done it.
JoeLena is offline   Reply With Quote
Old 07-14-2011, 06:43 PM   #2
i would say thats a great spot to put a cleanout.
Old 07-14-2011, 06:51 PM   #3
Rewards Points: 121
Well...don't really need one there, it's about a foot or so from the septic tank, and there's a cleanout 10 feet away inside.
I saw a how to on another site, looks pretty easy after the digging, they used a flexible coupling on one part of the peice to replace.
The Following User Says Thank You to JoeLena For This Useful Post:
oh'mike (07-14-2011)
Old 07-14-2011, 06:59 PM   #4
you will probably have to cut a section to get the rubber couplings on the pipe. if a fitting is broken then thats something else. in the picture it looks like 2 fittings butted up next to each other.
Old 07-14-2011, 10:29 PM   #5
Lots of digging.
Hatsee is offline   Reply With Quote
Septic tank full? MikeKy55 Plumbing 12 03-08-2011 05:37 PM
All problems have a solution (septic tank resolutions) Snav Plumbing 3 04-23-2010 09:11 AM
Garage over Septic tank and Leach lines canyonbc Building & Construction 11 01-13-2010 10:48 PM
Magnolia tree + septic tank question/problem Jemo General DIY Discussions 5 01-18-2007 09:08 AM
Foundation over abandoned septic tank handyman923 Building & Construction 2 09-29-2005 07:12 PM
