Kitchen Water Pressure Suddenly Weak - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-02-2012, 01:55 PM   #1
Kitchen water pressure suddenly weak
Happy New Year everyone!
Until today.
Fixed a pinhole leak in a copper pipe. Oops. Wrong pipe. Fixed the pinhole leak in the leaky pipe. Turned water back on. Good pressure to everywhere except the kitchen sink on the main floor. Pipe replacement was in the basement. (Seem to be getting regular pinhole leaks in the laundry room.) It's a single out faucet. When I first turn it on, it sounds like good water pressure then quickly fades. It also no longer cuts off but trickles out for a few seconds as the pressure dies away. I've used regular 1/2" copper pipe with sharkbites for connectors. I've done this before and never had a problem so I'm a little stumped. Any ideas what I should be looking for? Replace the faucet and hope it's a coincidence? Any help greatly appreciated. Thanks.
Bobby55 is offline   Reply With Quote
Old 01-02-2012, 04:34 PM   #2
First thing I would do is screw off the aerator off the end of the spout and see if it is clogged. Hopefully it is the problem.
broox is offline   Reply With Quote
Old 01-02-2012, 04:40 PM   #3
Rewards Points: 582
is the pressure bad on hot and cold in kitchen...if so apply above post clean aerator,,
Old 01-02-2012, 04:40 PM   #4
Rewards Points: 14,306
Somethings very wrong with your water if the supply lines are getting pin holes in the piping.
Hard copper pipes should last several life times.
I'd get it tested.
Old 01-02-2012, 04:41 PM   #5
Rewards Points: 582
the house could of had a water softner in that used alot of salt,,,,will cause pin holes in copper tubing???????
Old 01-02-2012, 05:46 PM   #6
DIY staff
Rewards Points: 7,174
Is it a single handle with a pull out faucet head?
If so--there is a screen in the line between the hose and the head---also there is a tiny back flow preventer between the valve body and the hose--Either one causes those symptoms when clogged.
ben's plumbing (01-02-2012)
Old 01-02-2012, 07:34 PM   #7
Thanks for the tips so far. I've checked the aerator and it seems OK. It's a pullout faucet head so I'll try taking that apart and see what happens, maybe even pull a connector off the faucet plumbing and see if I have pressure there. It's just too coincidental. It's a sudden change in pressure, not gradual over time.
ps we have hard water here, water softener is in place, pipes are now about 30 yrs old, this is 3rd pinhole in last 2 years. Seriously thinking about replacing future pinhole leaks with pex.
Old 01-02-2012, 07:43 PM   #8
Rewards Points: 582
yes thats what i thougth softener ...pex may help...
Old 01-02-2012, 09:58 PM   #9
had the same issue with a client this blog helped
john howard4321 is offline   Reply With Quote
Old 01-02-2012, 10:05 PM   #10
jproffer's Avatar
Rewards Points: 716
x2
I'd bet 100 that the check valve (backflow preventer, mentioned above) is the trouble.
jproffer is offline   Reply With Quote
Old 01-02-2012, 10:21 PM   #11
Is it easier just to replace the whole faucet? I can bump it up on my round tuit list.
Old 01-02-2012, 10:54 PM   #12
jproffer's Avatar
Rewards Points: 716
Changing the check valve shouldn't be too difficult.
If the faucet is relatively new, call the company...they may even send you one for free. Not sure if they're available seperately via retail....maybe.
Old 01-03-2012, 06:49 AM   #13
DIY staff
Unhook the hose from the valve body and turn on the faucet-Put a bucket under the tube)
That will often blast out the offending part----and let you know if the hose is the problem---
Old 01-03-2012, 08:24 AM   #14
We have had our bathtub taken out and a walk in shower put in, since that time the hot water presure in the shower is very weak, we have tryed new shower head but nothing works
delgary is offline   Reply With Quote
Old 01-03-2012, 08:35 AM   #15
delgary If you have a question it would be best to go back and post your Thread.
With two people getting suggestions on one thread no one knows hows talking to who.
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
Trouble with kitchen sink/hot water kid320 Plumbing 3 04-29-2010 10:31 AM
Installing Sprinklers appear to have caused Water Pressure to DRASTICALLY increase geminigirl Plumbing 3 11-12-2009 12:04 PM
Low hot water pressure on kitchen faucet Ultrarunner2017 Plumbing 7 12-19-2008 09:49 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
