Kitchen Water Leak! - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2012, 08:16 PM   #1
Question
kitchen water leak!
So we just purchased a forclosure and unbeknownst to us the freakin new dish washer was slowly leaking behind the cabinet for about a month and a half! (ever since the water main was turned on) The water never came out onto the vinyl floor for us to see, but since the edge of the vinyl was curled up under the counter it went under the floor!!! The underside of the vinyl acted like a sponge and by capillary action the entire kitchen floor got water under it!!!
Please help me answer some questions I have:
Im not sure where the majority of the water was going. Since the dirt crawl space now has about an inch of water in spots I assume it was getting down through the floorboards. Maybe at the seams in the floor or at the wall??
Over a month even a small leak like this could add up to a lot of water right?
Its been about 4 days since I shut off the leak, but the crawl space is still about the same as far as water. Will the water slowly go away on its own? Maybe the ground beneath the house is just saturated from the leak? Should I try to dig a hole and install a pump to suck out the water or just wait awhile.
I'm in the process of ripping out the particle board underlayment which is pretty wet in some spots, but I'm just freaking over the wet crawl space!
joregon3597 is offline   Reply With Quote
Old 03-15-2012, 08:20 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Nothing to freak out about. If you can ventilate the crawl space and place a fan blowing over the area and you should be fine.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-16-2012, 12:06 AM   #3
Rewards Points: 13,450
I think it's amusing your freaking out about water in a crawl space when your facing having to now have to remove all the countertops, counters and all of the subflooring to fix the real problums this leak caused. And it's going to have to be done soon or mold will set in.
Partical board is the last thing anyone should use for a subfloor. It will soak up even moisture in the air never mind a real leak. It swells up then becomes like oatmeal.
It's no longer an exceptable subfloor for any type of flooring.
Old 03-16-2012, 02:39 PM   #4
Question
Ok still have questions
Although I'm still worried about the wet crawl space, I'm trying to focus on the floor repair:
I'm not totally sure what the underlayment is. Its some type of particle board, maybe MDF? It looks like compressed saw dust, no big flakes in it. Below that is plywood.
A leak like this going on for a little over a month....will the plywood subfloor underneath the particle board survive? I'm planning on tearing up all the particleboard and drying out the plywood underneath.
Thanks for any help
Old 03-16-2012, 02:45 PM   #5
Civil Engineer
Rewards Points: 4,694
If the plywood is exposure rated (it will say so on the plywood), it is possible you can salvage it by drying it thoroughly and checking it for delamination. The particle board is history, might be worth burning but more likely just throw it away. As for the crawl space, if you stopped the lead, as the other poster noted, put a fan down there and eventually it will dry out. Since you have so much work to do, it might be a good time to add a vapor barrier over the crawl space, you could consider plastic sheeting, or even go whole hog and place a couple of inches of concrete on the soil.
Daniel Holzman is online now   Reply With Quote
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
Low water pressure after fixing leak. SirDrums Plumbing 5 06-09-2010 10:04 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
mysterious water leak Stanzaw Plumbing 11 02-13-2009 09:57 AM
