Old 06-22-2009, 01:37 AM   #1
Smile
Kitchen vent stack
Does anyone know what the min. distance between the horizontal vent stack and the drain is? The vent stack is partially blocking the supply line to the faucet and I want to know if "shortening up" the vent will affect the drain.
uphogger is offline   Reply With Quote
Old 06-22-2009, 07:08 AM   #2
Kitchen vent stack
Not sure I understand your question. The vent is supposed to go all the way through the roof, or to the outside. You do have some leaway as to the routing.
Old 06-22-2009, 10:32 AM   #3
Kitchen vent stack
The vent line from the sink should be tied into the main vent or go up through the roof on it's own. Neither one of these would allow "shortening it up". Not really sure what you mean.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-22-2009, 04:54 PM   #4
GC/Master Plumber/Mech
Kitchen vent stack
If your asking what the distance is on a horz run from a traped fixture to a vent stack is there is no min only max 1 1/4" is 5ft and 2" is 6 ft
also if you are talking about a vent off a sink or lav then the vent must go 6" above flood level rim before turning horz
kitchen vent bhale Remodeling 1 12-19-2008 12:26 AM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 07:49 PM
Vent stack for kitchen sink stan 41943 Plumbing 19 03-16-2008 06:50 PM
Can you remove hotwater vent stack? rhino1616 HVAC 1 03-11-2008 09:43 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
