-   -   kitchen sprayer troubleshooting (http://www.diychatroom.com/f7/kitchen-sprayer-troubleshooting-73584/)
jhustwit 06-13-2010 12:39 PM
Can anyone help me figure out what's wrong with my kitchen sprayer?
I have a price pfister kitchen sink with sprayer. the sprayer stopped working one day. No weak stream, no dribble, nothing.
I removed the diverter valve and cleaned it (it looked fine), reassembled, and the sprayer worked! An hour later, however, it stopped working again. :censored:
So I bought a new diverter valve, installed it, and the sprayer worked! until an hour later, when it didn't. :censored: :censored:
Do I need a new sprayer and hose or could it be something else? Thanks!!
Yoyizit 06-13-2010 12:43 PM
Could be your water heater plastic dip tube is disintegrating. Look in the aerators of sink faucets.
jhustwit 06-13-2010 12:45 PM
thanks. the house is fairly new, built in 2005. would that disintegrate already?
bob22 06-13-2010 05:19 PM
What did you get out of clogged valve? What did it look like?
jhustwit 06-13-2010 06:52 PM
Hi Bob,
The valve was not clogged and there was no visible crud on it. I just removed the valve, soaked it it vinegar, rinsed it, and reassembled it.
Yoyizit 06-13-2010 08:43 PM
Maybe there is a Tech Bulletin from Price Pfister on this problem.
Mike Swearingen 06-14-2010 02:46 AM
If replacing the diverter valve and the other things that you tried didn't fix it, I would just repalce it. They are not expensive.
Good luck!
Mike
