Old 11-16-2010, 02:46 PM   #1
Kitchen sink's plumming leaking
Hello, I have a kitchen sink that is leaking in the drain pipes. The sink has a straight metal pipe coming from the sink. Then that connects to PVC piping that does the curve thing. The metal pipe has become disconnected from the PVC piping
I have tried to put the pvc piping back on the metal pipe, but it doesn't stay there it just slides back down. What is the trick to get the PVC pipe to stay connected to the metal pipe?
Thank you
jburchill is offline   Reply With Quote
Old 11-16-2010, 07:14 PM   #2
I think you may be referring to a compression fitting, there should be a nut on the pvc pipe you can tighten with a channel locks.
Ltnicks is offline   Reply With Quote
Old 11-16-2010, 07:43 PM   #3
call me E
TheEplumber's Avatar
Remove the pipe (flanged tailpiece) off the bottom of the sink. Take it to hardware store and buy a longer one. Also replace the nut and gasket at the bottom of the tailpiece. Sounds like your tailpiece is a little short and it also won't hurt to replace the nut and washer too. You can use pvc parts
Old 11-17-2010, 11:15 AM   #4
thanks for the replies, I took the tailpiece off last night and I am going to buy a new one today. The old was was metal with the bottom rusting out and braking.
I have a few questions still. I am going to buy a 1 1/2 tailpiece that is 6 inches long.
Does it matter if I buy metal or pvc when the old one was metal?
Do I need anything special to get the tailpiece to stick with the p-trap? Glue or any of that sort?
Thank you
Old 11-17-2010, 11:31 AM   #5
Master General ReEngineer
Bondo's Avatar
Ayuh,... Plastic is Fine...
as noted above, the joint you're asking about Glueing is a Compression Joint...
Totally mechanical, 'n needs to just be tightened...
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
New kitchen strainer leaking on Kohlr Cast-Iron sink wysiwyg6000 Plumbing 2 01-04-2010 09:47 PM
Rough height of supply lines fro both kitchen and bath sinks DPlunkett Plumbing 2 06-05-2009 05:39 PM
Urgent help on leaking bath tub to kitchen surepan Plumbing 6 05-05-2008 06:39 AM
Two kitchen sinks on one vent? Alsomee Plumbing 1 09-30-2007 08:36 PM
