Old 11-01-2009, 06:22 PM   #1
Default Kitchen Sink water pressure
Just moved in. I have an odd problem, only in my kitchen sink. When I turn on the water hot/cold it takes a few turns for the water to come out, and when it comes out like the valve is all open (Full flow 100%) then I can back it back to get the proper flow. It' a hastle, having to wacth out as to not get drenched every time you turn on the water. Any ideas? (all other sinks/ showers flow fine)
johnrad is offline   Reply With Quote
Old 11-04-2009, 05:51 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
What brand of faucet? Single handle? Dual handle?
Probably just need an inexpensive repair kit for the internal parts.
Mike
Mike Swearingen is offline   Reply With Quote
Tags
sink, water pressure
More On This Topic
Today we’re installing a kitchen sink in a rebuilt counter. We already have the sink secured with the braces and everything. The next step that we want to do is to actually install the sink supply lines onto the faucet valves. You want to loosen... Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
This is Christopher with expertvillage.com. I'm getting water now. I'm using hot water just because it works better on cleaning glass. If you don't have hot water it doesn't matter, any water works. I'm getting this out of my kitchen sink. I have big... Read More »
How to Caulk a Kitchen Sink
How to Caulk a Kitchen Sink by Expert Village
Once you have all the plumbing done and all the water connected up, you want to take some 100% latex silica caulking, and press it hard up against the edge of the sink. Let it get everywhere. Make sure you press it up against the sink really hard. Once... Read More »
I’m Lee. I have a degree in architecture and about ten years experience in construction field and today we are doing a kitchen remodel and we have to cut the hot water pipe back about four to five feet away from where it should be. So what you want... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 12:02 PM
bathroom sink pressure issue. tgamblin Plumbing 4 04-27-2009 02:21 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 01:31 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 08:55 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
