Kitchen Sink Valve Placement ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-26-2013, 10:26 AM   #1
Rewards Points: 236
kitchen sink valve placement ?
i am planning my kitchen sink plumbing. i was think, can i place the shutoff valves close to the door ? my wife is disabled. and if she ever needed to shut the water off, she would have a real hard time reaching back where they are normally put.
i am thinking = 1/2 throught the floor/base cabinet, close to the door. ball valves (much easier for her to work, and to see that they are "worked"). then 1/2" to the fittings for the flex hoses.
what do you think of this idea ??
also. do they make ball valves that solder directly to 1/2 copper ?
or fittings for the ball valves to thread to ?
do they make fittings for the sink, DW, and fridge supply ? to solder onto 1/2 copper .
thanx
Fix'n it is offline   Reply With Quote
Old 10-26-2013, 10:50 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 830
What you propose is a good idea and not that difficult.
1/2 copper sweat or compression straight stops are available.
If you want larger handles use 1/2" ball valves and then an adapter to what ever.....
Adapters are available for just about anything, just need to to search for them, not just at the box stores too.
Old 10-27-2013, 08:23 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
What if you just drilled the handles on the ball valves and installed stiff wire extensions on them so the could lay flat on bottem of cabinet but pulled on when needed to shut the valves off in an emergency?
That way they could be removed easily later on if not needed anymore and you wouldnt have to worry about replumbing things.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 11-03-2013, 08:32 AM   #4
Rewards Points: 236
got it done. no leaks and works well. dish washer should be here any time now, yeah, its sunday.
The Following User Says Thank You to Fix'n it For This Useful Post:
jmon (11-03-2013)
Old 11-03-2013, 08:36 AM   #5
plummen's Avatar
The copper looks nice,I dont think Ive ever seen a p-trap layed on its side before though.
How exactly is it the p-trap working?
Old 11-03-2013, 09:06 AM   #6
Rewards Points: 236
thanx. after posting, i said = what problems will they find with it.
yeah, you like that. well, you aint seen nuthin.
i forgot to buy a kit. so i had to "make do" with what i had. the trap is just to the right of the pic. then an elbow over to the elbow that you see connected to the sideways trap. take a guess on how the 2 elbows are connected. a hint = it can go 200mph
oh, and its not leaking. and is, of course, temporary.
plummen (11-03-2013)
Old 11-03-2013, 09:26 AM   #7
Plumber
Rewards Points: 830
Every plumber has duct tape ....
The copper looks nice! Good job
The Following User Says Thank You to TheEplumber For This Useful Post:
Fix'n it (11-03-2013)
Old 11-03-2013, 09:52 AM   #8
Rewards Points: 2,040
The horizontal P trap is awesome... I bet it holds a great trap seal..
Old 11-03-2013, 09:56 AM   #9
Rewards Points: 236
ok, lets all have a chuckle
darn DW is 34" tall . yet another problem to work through. i thought they made em all the SAME size. and these things are getting freaking expensive.
kitchen sink valve placement ?-img_2225.jpg   kitchen sink valve placement ?-img_2226.jpg
Old 11-03-2013, 10:00 AM   #10
plummen's Avatar
Now thats funny,I dont care who ya is!:laughi ng:
Old 11-03-2013, 08:58 PM   #11
Rewards Points: 236
yeah, it is funny. but, its working. only has to last a few eeks.
Old 11-04-2013, 05:26 AM   #12
DIY staff
Rewards Points: 7,174
I've seen worse that was permanent!
Remember---to be code compliant---we need a separate p-trap for each fixture in this area----
A Ram bit will allow you to cut a pipe out of a fitting,if you ever need to do that----
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Venting inadequate with AAV Kitchen sink DownStream Plumbing 1 07-31-2012 11:57 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
