Kitchen Sink Supply Lines Are Reduced. Why? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-19-2012, 07:49 PM   #1
Rewards Points: 12
Kitchen sink supply lines are reduced. Why?
My supply lines under the kitchen sink are 1/2" and then they are reduced to 1/4" before connecting to the 3/8" flexible supply lines. My water pressure for the kitchen sink is horrible. This may be due to all the crud that has built up over the years. I'm getting ready to install a new sink and faucet. Should I remove that reducer and connect the 1/2" copper pipe to the supply lines directly? I don't understand why it would be set up this way. Someone mentioned that it is to increase water pressure but it sure isn't with the current faucet but it is also plugged up pretty good with buildup. Thanks for any advice.
mi_fiveo is offline   Reply With Quote
Old 07-19-2012, 07:58 PM   #2
Rewards Points: 582
I would install new crome shut off valves....5/8 od compression x 3/8 od compression ball valves with new flexible supply direct to base of faucet...thats a normal install.....make sure you flush lines...
Old 07-19-2012, 11:10 PM   #3
Rewards Points: 12
Can you use compression fittings with hard copper pipe? I thought they were only for soft flexible copper pipe.
Old 07-19-2012, 11:55 PM   #4
Yup, done all the time.
VIPlumber is offline   Reply With Quote
Old 07-20-2012, 11:41 AM   #5
If there is galvanized pipe in the house that may be the problem. Galvanized pipe fills with rust and restricts the flow to the fixtures. You may need to replace some of the branches that feed the fixtures such as your kitchen sink. If you are going to replace your sink this would be the best time to also do the re-pipe. The flexible connectors that feed the faucet from the shut-off valve up are plenty sufficient when the lines are clean.
As to your other question, you can use compression type valves on hard copper but I have found it better to sweat a male adapter onto the copper and use a female ended shut off valve. Less leaks that way! Also, when you need to replace the shut off valve it is simple to do.
ldyplmr is offline   Reply With Quote
Old 07-20-2012, 12:34 PM   #6
Homerepairguy's Avatar
Rewards Points: 998
A note of caution when buying your new kitchen sink faucet. I replaced our old faucet because of old age. While doing that, I replaced the flexible supply lines with the same size as the old ones.
The water flow from the new faucet is noticeably less than the old faucet. I'm not sure if there's a water conversation thing going on with the new faucet but since the supply lines are the same, it has to be the new faucet. Suggest paying good attention to the water flow specs for your new faucet.
HRG
Homerepairguy is offline   Reply With Quote
Why does my Kitchen Sink Smell? Syz Plumbing 10 10-30-2011 10:13 PM
Help with Kitchen sink! not draining, garburator blows water up 2nd sink aldous314 Plumbing 7 06-25-2011 08:56 AM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 12:28 AM
bathroom sink supply line height bluebee1314 Plumbing 2 03-28-2007 05:47 AM
Old Water Supply Lines in Kitchen and Bath Faucets skittlzski Plumbing 2 08-08-2006 09:13 AM
