Kitchen Sink Supply Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2010, 06:53 PM   #1
Send a message via AIM to Steven Z. Send a message via MSN to Steven Z.
The kitchen sink faucet has been giving the family a lot of trouble for years now, and just recently is started dripping so bad we had to turn off the cold water supply. The drain is also blocked somewhere down the way, and putting a snake down doesn't do much. We have to have a bucket in the sink basin to catch the waste water and periodically dump it in the front yard.
My mom finally got a new faucet and I've been trying to get the old faucet off for a week now. The problem is that the supply lines for both the cold and hot are metal pipes, not flexible tubing. They are bolted on to the inputs on the old faucet. I've been using a plumbing wrench, pliers, hands, etc but thee is literally no room to even turn the wrench, assuming I can even get a grip on the bolt. Here is a crappy drawing of what it's like:
There are just a few inches around the supply line, making it impossible to turn the bolt. Is there a special wrench or "trick" to getting this off? Once we do get it off, should we replace the supply lines with the flexible tubing?
Steven Z. is offline   Reply With Quote
Old 04-02-2010, 12:58 AM   #2
Do something
D'Brie's Avatar
Check out the D.O. Smith Co. for angle stop wrenches.
D'Brie is offline   Reply With Quote
Old 04-02-2010, 09:09 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Have you tried a basin wrench?
Journeyman Plumber
Old 04-02-2010, 09:14 PM   #4
Household Handyman
Rewards Points: 1,408
"Steven Z": I know you don't want to hear this one, but--I have had to remove entire sinks to get some older faucet assemblies and lines off. I have a number of "special" tools which should do the trick, but every now and then I run across another one that wins. It seems that some of the older faucet and lines get what's know as "galvanic corrosion" (which is when dissimilar metals touch and corrode) and are like welded together. Maybe look to see how your sink is held in and determine if this may be a better way. David
New kitchen strainer leaking on Kohlr Cast-Iron sink wysiwyg6000 Plumbing 2 01-04-2010 08:47 PM
Ideas Regarding Kitchen Remodeling Kristal Kitchen & Bath Remodeling 2 12-20-2009 09:44 AM
No hot water at kitchen sink allwet Plumbing 9 12-02-2009 07:37 AM
Kitchen sink P-Trap location question. kgphoto Plumbing 3 09-18-2008 01:11 PM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 04:23 PM
