Kitchen Sink Stack - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2013, 09:47 PM   #16
Rewards Points: 236
excellent. i have the room for that.
Fix'n it is offline   Reply With Quote
Old 08-14-2013, 08:44 PM   #17
Rewards Points: 236
i now have what i believe is everything i need to do the job. pics this weekend.
Old 08-17-2013, 09:03 AM   #18
Rewards Points: 236
hows this ?
nothing is glued. and i need to get another elbow for where it comes out of the wall. i thought i bought more of them, but somehow i didn't = breaking my own rule = buy MORE than you think you need.
anyway. everything has at least a slight downhill flow.
and the cleanout, should that be turned up some ?
also. i need to connect to a steel pipe for the roof fitting. would a fernco be ok ?
how far out of the wall should each fitting be ?
Old 08-18-2013, 08:19 AM   #19
Rewards Points: 236
hmmm, no comments. too me, thats not a good thing.
Old 08-18-2013, 09:56 AM   #20
Plumber
TheEplumber's Avatar
Rewards Points: 568
Looks fine, add nail plates, stub out the trap arm centered under one of the sink drains- preferably not the one with the disposal. this will make your continuous waste configuration a breeze when setting the sink.
Old 08-18-2013, 10:00 AM   #21
Rewards Points: 1,878
If your sink has 2 bays make sure your drain is offset to center of one of the bays. And nail plate. I honestly would not have a clean out. Its easy enough to remove the tubular trap and snake. Your top plate and bottom plate on the wall need 4 by 8 nail plates for code reasons.
Ghostmaker is online now   Reply With Quote
Old 08-18-2013, 10:12 AM   #22
Rewards Points: 236
thanx, fella's. i am getting started on this, this morning.
i am getting a large single bowl sink. had one in last home, and LOVED it.
the drain is going to be offset.
nail plates. are those sheet metal with holes in em ?
Old 08-18-2013, 10:17 AM   #23
Rewards Points: 236
oh. i took out the pipe that was the old vent. it was COMPLETELY plugged with muck.
tree junk loves to cover my property. if i left the opening on the roof open, i know as a fact that the vent would get plugged in the future. i am thinking about some kind of hat for it. what do you think ?
Old 08-18-2013, 10:29 AM   #24
Plumber
Rewards Points: 568
What we were saying about the drain is to offset it so it centers under a basket strainer for a two compartment sink. If you use a single bowl- you can center it.
This makes the final connect go smooth without off setting under the cabinet.
Nail plates are heavy gauge metal. Keeps drywall fasteners from penetrating the pipe.
You should use structural plates at the locations Ghost referred to. This re-enforces your framing members
The Following User Says Thank You to TheEplumber For This Useful Post:
Fix'n it (08-19-2013)
My kitchen sink smells like sewer kasgirl Plumbing 7 11-23-2012 04:57 AM
Installing new Vent pipe for kitchen sink dtweiss74 Plumbing 1 10-21-2012 02:11 PM
Why does my Kitchen Sink Smell? Syz Plumbing 10 10-30-2011 10:13 PM
Moving kitchen sink teachtech Plumbing 4 08-08-2010 10:13 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
