Kitchen Sink Spills Out On Basement Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-03-2012, 11:06 AM   #1
Robert
RMo8235376's Avatar
Rewards Points: 12
Kitchen Sink Spills out on basement floor
My kitchen sink drain is overflowing onto the floor downstairs via the drain pipe that the water softner tube goes into, it cant handle even 1/2 full sink being drained down.
All pipes are clear, 2 inch, the vent pipe to the washer & drain is tied in next to it, & goes right into the floor.
No problems of backup with washer running & draining.
The "side" pipe off the kitchen sink drain that the watersoftner goes into is 2ft. 4" off the floor, the vent pipe tied into both of them goes straight to the roof.
Any ideas on this one?
RMo8235376 is offline   Reply With Quote
Old 09-03-2012, 08:05 PM   #2
Bombastic Idiot
notmrjohn's Avatar
You got me confused. Pictures? Drawing?
" drain pipe that the water softner tube goes into" this drain pipe is a stand pipe? open on top? If a closed connection how is water getting out?
"All pipes are clear" you mean of obstructions? How do you know? Obviously not if stand pipe is over flowing.
"vent pipe to the washer & drain is tied in next to it, & goes right into the floor" Into the floor? Down into floor? Up through floor above? Washer in basement? Washer drain thru its own standpipe?
The "side pipe" sentence I cant visualize. The sink did drain via the pipe that the water softner drained into, now the water softener seems to drain into the sink drain.
2ft 4" off floor..its a horizontal run? and there is another vent stack? Seperate from washer vent?
I'm not pickin on ya, I just can't grasp it.
Where is the water coming out of the drain pipes? If it wasn't over flowing where would it go? What is the next thing down stream connected to that line? Is it draining ok? If so there is an obstruction between there and where the sink connects to that line.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-04-2012, 09:37 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Pictures would be awesome.
Journeyman Plumber
Old 09-06-2012, 01:38 AM   #4
Robert
RMo8235376's Avatar
Rewards Points: 12
What do you mean?
Old 09-06-2012, 06:05 AM   #5
Rewards Points: 1,596
Post a picture or two of what you described.
bob22 is offline   Reply With Quote
Old 09-06-2012, 07:04 AM   #6
Rewards Points: 582
its clogged there.. run snake from where water is comming out...
Old 09-06-2012, 10:58 AM   #7
Bombastic Idiot
notmrjohn's Avatar
What do you mean?
That's what i'm asking you. ben condensed my answer down nicely, "run snake from where water is comming out.."
A man of few words that ben, That's good, the ones he doesn't use are left over for me to use.
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
