Kitchen Sink Shut-off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-19-2011, 09:44 PM   #1
Kitchen sink shut-off valve
I used the shut-off valves under the kitchen sink to turn off the water while installing a new dishwasher. I've now connected everything and re-opend the shut off valves, but am not getting any or much water flow. The main valve to our house is still open and water flows in the bathroom faucets. What's up?
Claytonka is offline   Reply With Quote
Old 05-19-2011, 09:52 PM   #2
Just call me Andrew
Rewards Points: 1,020
How old are the valves? Sometimes they break and get stuck in the off position...might need a replacement.
Andrew
secutanudu is offline   Reply With Quote
Old 05-20-2011, 06:43 AM   #3
Or the washers disintegrate and clog the valve or the next narrow point. Is the aerator off, if not remove it, those chunks often end up there.
The Following User Says Thank You to Just Bill For This Useful Post:
secutanudu (05-20-2011)
Old 05-20-2011, 08:45 AM   #4
Thanks Bill & Andrew. The valves are about 20 years old and haven't been closed/operated much in that time. The handles turn freely but seem to have some resistance, as if connected to something, but then litte flow is coming through. Since both are dogin the same thing, hopefully the blockage is at the aerator as noted.
I'll check the aerator for blockage. If not the aerator, could the valve itself be clogged by the same crud, and if so, can it be cleared, or would it need to be replaced. Thanks again.
Old 05-20-2011, 08:50 AM   #5
Just call me Andrew
Are those valves threaded on or soldered? Can you see?
If they are threaded, it's pretty easy to replace them.
Andrew
Old 05-20-2011, 10:17 AM   #6
Rewards Points: 3,130
If you do, get quarter-turn ball valves. They're much easier to operate.
Old 05-20-2011, 10:19 AM   #7
Soldered I'm afraid. Accessible, but hard to get to under the sink.
Leaking shut off valve, am I that inept??? ChrisDIY Plumbing 12 07-28-2012 07:52 PM
Kitchen sink venting issue erm213 Plumbing 9 05-24-2011 02:01 PM
How to Find and Shut Off the Main Water Valve PUTP Plumbing 16 01-08-2011 09:35 AM
Kitchen sink centered on cabinet? sillyboy22 Plumbing 3 03-02-2010 09:16 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
