Kitchen Sink Plumbing: Is This An 'S' Trap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2012, 05:22 PM   #1
Kitchen sink plumbing: Is this an 'S' trap?
My landlord is an elderly man, and very hard to deal with. There is something wrong w/my kitchen sink plumbing, and last time I asked him about it he said, "oh, you just gotta keep the pvc pipes tightened, it's the nature of the material"....So I think he's just trying to get out of dealing with the problem.
Upon further research, I found that S traps are illegal now, and If i can prove that there is an S trap on MY sink, that will give me some leverage on getting him to fix my problem (legal blackmail?)
Can ANYONE tell from this picture, If i have an S trap or a P trap?
Thanks in advance
Jess
jsweet1981 is offline   Reply With Quote
Old 12-31-2012, 05:30 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
Yes that is an s trap. What problem are you having?
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
jsweet1981 (12-31-2012)
Old 12-31-2012, 05:32 PM   #3
my problem
The tail pieces connected to both my sink basins are not secure, nor have they ever been (the connector pieces come loose, no matter how many times I tighten them) I think it may be an issue with the plastic washer, because it doesn't seem to fit, therefore, doesn't create a tighter hold...I have had to put a bucket under the right side for a long time now. In the picture, you can see that I have the pipes propped up by a container.
Last edited by jsweet1981; 12-31-2012 at 05:38 PM. Reason: watnted to elaborate a little more
Old 12-31-2012, 07:01 PM   #4
Rewards Points: 13,960
Have you pulled it apart to see if the plactic washers are even installed right side up?
Old 12-31-2012, 07:38 PM   #5
Well i put the washer in question in both ways into the part it originally was in...which is why i'm concerned....when i last checked the pipes under my sink, it looked like that plastic washer was coming out of the pipe, It clearly doesn't fit it.
Old 12-31-2012, 08:59 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Being an "S" trap has little to do with the problem you are having.
More than likely the piping is not supported below the floor, and the weight of said pipe is pulling the slip joints apart. Crawling underneath the house and putting a strap of plumber's tape across the floor joists, or beams to hold the drainage up under the house should alleviate the problem you're having.
Journeyman Plumber
Old 12-31-2012, 10:09 PM   #7
yes...because, As a Tenant....I don't have access to outer pipes in the basement...Read what you reply to.....twice!
Old 12-31-2012, 10:32 PM   #8
Doing it myself
Alan's Avatar
I don't see where you said anything about not having access to the pipes. I'm not denying that he should have the problem fixed. I'm saying the S-trap has nothing to do with the issue. If he won't fix it, it shouldn't be that difficult. If it bothers you that much, it may be worth your time and effort to buy a little strip of metal plumbers tape and a couple of screws.
Furthermore, doesn't your state have protection for tenants to where they can fix deficiencies in the property (WITHIN REASON) and deduct them from the month's rent? If not, and he still refuses to fix it, and you still refuse to fix it yourself, maybe it's time to look for a new place to live.
If you don't like my responses, don't read them. Not even once.
Journeyman Plumber
Old 12-31-2012, 11:35 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 776
If the pipe is sagging and you don't have access to the crawl- put a riser clamp on the pipe in the cabinet.
Old 01-01-2013, 08:03 AM   #10
I have a special method i use on rental properties. Unscrew those plastic nuts glob urethane in there screw back together. It will never ever leak again, nor ever come apart.
paintdrying is offline   Reply With Quote
Old 01-01-2013, 08:20 AM   #11
That style trap will take two differant style washers.
The top left one uses one like this.
http://www.bing.com/images/search?q=...lectedIndex=31
Just look at the inside of the trap to see how one taper fits into the other.
The other washer looks sort of like this.
http://www.bing.com/images/search?q=...ectedIndex=465
Old 01-01-2013, 08:26 AM   #12
DIY staff
Rewards Points: 7,174
That was a crabby little snap----Please don't do that again.
Old 01-01-2013, 08:33 AM   #13
That has nothing to do with it my friend. My tenants have physical access to, we'll..... Everything.
Beaker0917 is offline   Reply With Quote
Old 01-01-2013, 09:47 AM   #14
Master Plumber
Javiles's Avatar
Rewards Points: 996
Newbie with an attitude,
Old 01-01-2013, 11:06 AM   #15
Rewards Points: 236
thats the easy fix right there. just unscrew the connections, clean, and caulk or glue.
Fix'n it is offline   Reply With Quote
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 08:29 PM
My kitchen sink smells like sewer kasgirl Plumbing 7 11-23-2012 04:57 AM
Kitchen sink replacement - plumbing questionable.... batistuta Plumbing 27 04-07-2012 12:04 PM
Kitchen island sink plumbing pics request BCP Plumbing 5 03-02-2009 02:40 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
