Old 08-06-2012, 10:57 PM   #1
Kitchen sink plumbing problem
I got an emergency call to come over to a lady friend's place to look at her plumbing. Yeah, it's not what you think, this is what I got to look at:
There's a blockage of some sorts in the pipes and water from the garbage disposal unit is backing up into the other sink. I took the whole assembly apart and flushed it and all sorts of goop came out but I suspect that there is a blockage downstream of the trap.
Question #1: Is this under kitchen sink plumbing plumbed correctly? My concern is the 180 degree turn of pipe after the trap.
In order to clean out the blockage downstream of the trap I'm going to have to cut the pipe because the section of pipe coming out of the floor has a 90 degree elbow affixed to the top of the pipe and I can't get my "DrainKing Bladder" (attached to a garden hose) around that bend and down into the pipe.
So, if I'm going to be replacing some of the piping, I might as well design a better flowing system but I'm not sure how to design such a arrangement.
Any suggestions on a redesign or on how to rebuild so that cleaning out the pipes in the future won't involve cutting?
AlexHouse is offline   Reply With Quote
Old 08-06-2012, 11:28 PM   #2
cut s trap off replace with a sani t on top of run up put a air admittance valve in i would turn the t so it point correct to use a sink adapter then a p trap and hit a center double sink drain tube Assembly
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 08-06-2012, 11:55 PM   #3
Doing it myself
Alan's Avatar
This is a better example of what you'll probably have to do to get it to hook up properly :
http://www.salsplumbing.com/wp-conte...disposal01.jpg
Nothing really wrong with what is there except for lack of a vent.....
If you have specific questions about this installation please post them so they can be addressed. I don't really know what your mechanical skills are like.
Journeyman Plumber
kitchen sink disposal drain trap problem mystic_cobra Plumbing 20 04-13-2012 10:13 PM
Resetting Undermount Kitchen Sink Voss Plumbing 0 02-24-2012 01:47 PM
Kitchen sink venting issue erm213 Plumbing 9 05-24-2011 03:01 PM
smell in basement from non-vented kitchen sink ahgill Plumbing 3 10-11-2010 03:39 PM
Rookie disconnecting kitchen plumbing bcarwell Plumbing 2 02-14-2008 12:29 PM
