Kitchen Sink Plumbing Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-16-2011, 10:52 AM   #1
Kitchen sink plumbing leak
The townhouse a friend of mine is renting out has a leak around the trap of the kitchen sink.
He is not in the area anymore, so he asked if I could take a look at it. I've had some experience doing minor plumbing work, and am fairly confident I can take care of things when seeing this picture.
The only thing that looks hairy is the buildup where the trap connects to the "adapter" piece. If I can't get remove the buildup, would I have to cut the adapter off of the pipe going into the wall? If so, how would I go about getting the replacement trap and adapter to go to the new, shorter pipe, since it will not be a standard distance away from the trap (assuming there is a standard distance)? Are there special adapters for just this situation?
Any help is appreciated.
bodekms is offline   Reply With Quote
Old 11-16-2011, 11:27 AM   #2
Rewards Points: 320
You could cut the stub coming out of the wall back, then extend it with a coupler and another short piece back to where it needs to be.
autx790 is offline   Reply With Quote
Old 11-16-2011, 01:31 PM   #3
Am not a fan of hard piping traps. I would cut the pvc back install a 1 1/2 trap adapter and then get a tubular p trap
jc60618 is offline   Reply With Quote
Tags
leak , trap
Plumbing leak in basement - HELP jamieblosser Plumbing 2 06-16-2011 12:44 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
temporary set up in utility room for kitchen renovation (sink; dishwasher) ilyaz Plumbing 3 01-25-2010 07:07 PM
Kitchen, sink, plumbing ?'s Canada 83trekker Plumbing 3 01-10-2010 02:31 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 11:10 AM
