Kitchen Sink Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2013, 07:41 PM   #1
Rewards Points: 48
Kitchen sink plumbing
I want to swap out our double-basin kitchen sink for a large single basin. However, whenever I find how-to information it always assumes the two sinks from the double connect under the sink and travel to the wall via a single pipe. But in sink, each drain travels into the wall separately where I'd guess they connect into the single main drain. Any suggestions/pitfalls/links of converting such a configuration into a single drain (with disposer) would be appreciated. Pic attached.
In addition to the drainage, I'm wondering overall support from a single drain? Would the new one need to be a center drain? It would be a drop-in sink.
boogie81 is offline   Reply With Quote
Old 09-09-2013, 08:43 PM   #2
Rewards Points: 1,706
Permanently cap at the wall with a scd 40 pvs cap the drain you will not use. You will need to 45 the other drain to the center for a ptrap and disposal.
The Following User Says Thank You to Ghostmaker For This Useful Post:
ben's plumbing (09-09-2013)
Old 09-09-2013, 09:08 PM   #3
Rewards Points: 48
Any concerns about installing a single basin with the drain to the side, where existing drain to disposer is located? That would be my preference and then makes the job simpler, avoiding the 45.
Old 09-09-2013, 09:29 PM   #4
Rewards Points: 582
either or your choice both will work out...make the choice get er done ben sr
Tags
disposal , kitchen sink , plumbing , sink , sink installation
Plumbing a washer/dryer combo into kitchen sink VersaBar Plumbing 11 01-18-2016 10:51 PM
Kitchen Sink Delimma.. shbhalla Kitchen & Bath Remodeling 3 08-28-2012 11:08 PM
smell in basement from non-vented kitchen sink ahgill Plumbing 3 10-11-2010 03:39 PM
temporary set up in utility room for kitchen renovation (sink; dishwasher) ilyaz Plumbing 3 01-25-2010 07:07 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
