Kitchen Sink Not Draining, Is It The Vent? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2011, 02:21 PM   #16
Mark Potter's Avatar
Rewards Points: 150
Originally Posted by oh'mike
Alan would know the answer --But he jumped off his roof the other day and I haven't heard from him since.
It depends on were the bathroom is connected there could be crap stuck right were it T's off from kitchen.
Mark Potter is online now   Reply With Quote
Old 10-13-2011, 02:37 PM   #17
DIY staff
Rewards Points: 7,174
Only of that sink has a wet vent from the upstairs sink---
possible but OP said that he rodded a short distance ---best to rod to the main sewer.
Old 10-13-2011, 02:47 PM   #18
Rewards Points: 150
Tu Shay! Mike, you always have the better answer on me lol
Old 02-12-2013, 04:38 PM   #19
Drain that won't drain but doesn't have a clog....
We have been having a clogged sink for the past 2 days and done everything from salt/baking soda/vinegar/boiling water to snaking the vent on the roof to 25 ft. snake down the main drain under the sink.......to no avail. It's like there was no air to push it down or let the water go down. We have plunged with the second side of the sink blocked so it could get suction. NOTHING worked. Finally, I decided to go into the bathroom and close the sink drain and the tub drain. Came back out to the kitchen and plunged hard again several times and VOILA !!! It drains fine now. No chemicals were necessary. We still have no idea what the cause was but it's working, so who am I to question why? Try blocking off your other sinks/drains so you are only getting suction to the one drain that isn't draining and see if that works.l Goood Luck
Originally Posted by gdav View Post
Hey guys, here's the situation (and thanks in advance for any help, this one really has me stumped).
A couple of days ago the basement kitchen sink stopped draining properly. I removed all the pipes connecting it to the sewer in the wall, cleaned them out and didn't find any real blockage (just some standard gunk that had built up). Connected it all back together and it's still not draining. I then snaked the sewer drain down two feet or so, at first it wasn't going down but I eventually broke through some stuff and the snake moved freely as far as it would go (3-4 feet). This is where it gets weird...
Hooked everything back up and it's still not draining. Also, when I started taking apart the connection at the end of the P-trap a lot of pressure was released (sputtering sound, water coming out mixed with air). At this point I figured it had to be some kind of pressure issue so I checked the vent.
Got up on the roof and ran water down the vent. It didn't ever fill up the vent, but I noticed the water level in the kitchen sink was rising. What really puzzled me is when I ran the hose down the vent and it got stuck at what felt like three or four feet ABOVE the place where the kitchen sink connects to the sewer, which wouldn't explain the water backing up. Should I assume there are two blockages? The hose seemed like it was hitting something pretty solid that wouldn't move from dropping the hose on it several times or blasting it with some water. Am I just hitting a corner or something and the only blockage is below the connection?
Thanks for the help!
Really not wanting to resort to a plumber here, but if that's what needs to happen....
Rabbit2 is offline   Reply With Quote
The Following User Says Thank You to Rabbit2 For This Useful Post:
brockmiera (02-12-2013)
Tags
clogged sink , kitchen sink , sewer vents
Drainage problems kitchen sink only. Raytanner Plumbing 1 01-10-2011 08:00 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
kitchen sink gargles when washer is draining Tonglebeak Plumbing 38 02-24-2010 01:43 AM
kitchen vent bhale Remodeling 1 12-19-2008 12:26 AM
REALLY slow draining kitchen sink! stenton Plumbing 2 12-04-2006 06:45 PM
