Kitchen Sink Leaking From The Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2008, 11:08 AM   #1
Kitchen sink leaking from the faucet
Its a slow drip from the faucet and I have no idea where to start. Its a two handled design. Just started dripping the other day and won't stop. Sometimes makes a screaming noise but its rare (only happened once or twice in the past two weeks). Any help would be greatly appreciated. I'm not sure of the brand but could find out if necessary.
I just realized that the sink is also leaking around the decorative cap at the base of the faucet/spout.
SharpieMarker is offline   Reply With Quote
Old 05-02-2008, 09:26 PM   #2
Can you post a picture of the faucet?
plumber Jim is offline   Reply With Quote
Old 05-03-2008, 07:44 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
You need to try to determine the brand name ifpossible, but if it's a two-handle faucet, it most likely is a compression-type faucet with washers on the end of the handle stems and o-rings around the barrel of the spout.
You will need to turn the water off to the faucet, and take it apart. Even if you can't find the brand name, you can take the stems with the old washers on the ends and the old 0-rings to a store to get matching replacements.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
laundry sink needs wall-mount faucet - can I cheat? bluebee1314 Plumbing 2 04-05-2008 11:45 AM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 06:49 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
Question about a kitchen faucet skwpt Plumbing 10 10-11-2007 06:54 PM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 07:37 PM
