Kitchen Sink Leaking From Base Of Spout (Delta). - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By RRH
  • 1 Post By RRH
Old 03-18-2017, 01:02 AM   #1
Rewards Points: 312
Kitchen sink leaking from base of spout (Delta).
When i turn either faucet on, water leaks out of the middle piece, where it screws together. I unscrewed it and pulled a cartridge type of deal out. Will replacing it stop the leak? If so, i guess i will have to go to a plumbing supply store, because i couldn't find anything that looks like that at Home Depot.
Here is where the leak is coming from:
And here is what i pulled out:
tireshark is offline   Reply With Quote
Old 03-18-2017, 02:00 AM   #2
Rewards Points: 2,440
Re: Kitchen sink leaking from base of spout (Delta).
They need new seal gaskets occasionally.
Most usually just buy new faucets, and be done, you might get the parts from Delta if you have the original paperwork, and / or can get the part # somehow.
ED
de-nagorg is online now   Reply With Quote
Old 03-18-2017, 05:50 AM   #3
RRH
Rewards Points: 322
That white part is not what you need.
Take the cap off. Then the actual spout will come off. May have to work it back and forth while pulling up.
Then you will see 2 o-rings that need to be replaced.
de-nagorg likes this.
RRH is offline   Reply With Quote
Old 03-18-2017, 05:53 AM   #4
RRH
Rewards Points: 322
pic
Drain Route and Venting for new kitchen sink drain (window above sink) joemc3 Plumbing 12 11-05-2016 06:17 PM
Question about Vigo 33" Apron sink fitting base cabinet Billm0066 Kitchen & Bath Remodeling 0 02-09-2016 09:57 PM
36" Kraus front apron sink in a 36" apron sink base - best way to cut/install? Quicksmoke Kitchen & Bath Remodeling 4 10-06-2015 11:18 AM
Washing machine making "glugging noise"; kitchen sink backing up; bad smells; UGH KDG Plumbing 5 01-04-2015 06:27 PM
Leaking kitchen sink kevin-redsoxfan Plumbing 1 01-14-2009 03:41 PM
