Old 03-20-2012, 02:28 PM   #1
Kitchen Sink Flange Pipe
Hello, quick question, I replaced the flange pipe on my sink, but the piece that connect to that to begin the P-trap keeps sliding down. How do you keep it from sliding down? Glue?
jburchill is offline   Reply With Quote
Old 03-20-2012, 02:33 PM   #2
A picture would sure help. Sounds like your missing a tapered plactic washer or you have the washer up side down.
Old 03-21-2012, 04:52 PM   #3
Sorry no pics yet, but I think I know what the problem. The original home owner taped it so it wouldn't slide down(which is the problem I am having). I think the reason for this its missing the top piece on the flange to connect to the piece that connects to the flange.
Shouldn't there be two pieces that screw together with that plastic washer in the middle?
Old 03-21-2012, 05:45 PM   #4
call me E
TheEplumber's Avatar
Maybe you have too much upward stress on the ptrap. If, when the trap slips down, it still has grade for drainage then you might consider leaving it in that position and lengthening the tailpiece.
No glue on slip joint assemblies. They're held in place by the nut and tapered washer- the taper seats against the ptrap
Kitchen sink venting issue erm213 Plumbing 9 05-24-2011 03:01 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
temporary set up in utility room for kitchen renovation (sink; dishwasher) ilyaz Plumbing 3 01-25-2010 07:07 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 09:39 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
